L
Last Ride
Hey all--
I have been researching braking options for our cars for some time. I have seen everything from o-ring stock calipers to Wilwood Dynalite II's to aluminum replicas of the stock brakes to Brembo's! My biggest concern would be the cost to benefit ratio of any of these systems. As far as weight and cost are concerned, the Wilwood conversion is tough to beat. My concern there is having too small of a rotor when upgrading to larger wheels. No one out there makes brackets for larger wheel/rotor combos. The Brembo system is the most complete overhaul, but starting at $1500 per axle, it might be the least practical. What do you folks think about the options out there? The stock brakes are not bad now, but I would like to save weight over the stock system and maybe even improve stopping power for a much hotter motor I am planning. What do you think?
