entropy454
My thermostat was leaking and I tried to loosen them up with PB Blaster and work them off. The seller gave me a thermostat and told me about using the anti-freeze greeze on the threads when I put a bolt in an aluminum intake. That should have been a warning to me that he had tried before and gave up.
Needless to say neither would move and the shorter of the two has not broken off. The bolts were either the original or very old. It broke below the intake line so I guess that means there is less to work out?
My worry is the bolt still intact. This is the stock 69 aluminum intake and I don't want to harm it. This intact bolt is in a raised tower and is screwed into more aluminum. Should I continue to try to unscrew the bolt or try to just drill it out also?
I plan on using reversible drills and a eazy-out kit. Does anyone know if they sell reversible drill bits at normal hardware stores like Lowes or Home depot?
thanks again and any suggestions are welcome.
jim
jim
