94conv.
I unplugged the ecm to check connections still trying to get to the bottom of my stumbling and dying problem. Still only does it after it sits after running for about an hour. After I plugged the ecm back in the problem started again, stumble and ran rough, didnt die this time though. I looked closer found a cracked green and white wire, not broken all the way but one strand is definately broken. This wire is on the ecm on bank "red" which is top left or inside connector. From what Ive read its the fuel pump relay wire. Would this cracked wire cause my intermittent stumble after it sits? If we wiggled all the connectors the car would act up also.
