Broken Throttle cable
  • Thread starter Thread starter Louis Bartay
L
Louis Bartay
Has anyone ever replaced the throttle cable and housing on a 95/96 LT1/LT4? After removing the cable and housing from the throttle body and the cruise control the cable housing comes apart in two pieces, there is a square button that when pressed the center piece looks like it will come out so the lead barrells will pass thru. In need a GM manual to look at the cable and how two seperate the center of the cable housing. I need someone to email the pages from a GM manual for replacing the throttle cable from the throttle body to the cruise control.
Thanks Louis
Thanks Louis
Shoot me an email so I can send you some JPEGS
Mike
cable
Mike
E-mail is on the way, you Rock and I hope you have Happy Holidays
Louis
Louis
I am scanning right now you should have mail in a few minutes!
Mke
You have mail. Did that give you the info you needed for the cruise control cable? Sent you the HVAC vacuum diagram too.
Thanks, I recieved five jpegs, I see what the button is for now. I have to replace the whole cable set from the throttle body to the cruise control.
Happy Holidays
Louis
Happy Holidays
Louis
You should have 17 five for the cable, and one for the vacuum lines and 12 for the hvac controller.
Mike
