LanceB
So my brother decided to put a shift kit in his 77. He was almost done when the last bolt he was tightening down in the valve body broke off. Very frustrated because the torque wrench was set a little lower than what it called for to be safe. He is torn on what he should do. There are 11 bolts that hold the valve body on.
After looking down in the hole with a flashlight my first thought is to leave it alone (gulp) because I think we could make a bad problem worse by trying to get it back out and I don't see how this particular bolt is going to affect anything since there are 10 others surrounding it holding this thing on just fine. I have had TERRIBLE luck trying to drill and easy-out broken bolts in the past. Man 3 hours and near perfect execution of the directions to put this thing in has gone to crap real quick. Any advice appreciated.
