Antz81
Replacing the seat belt in my 81 as someone had put fixed (3 point) belts in, and they were just annoying me.
Started on the drivers side found two of the bolts were the wrong bolts. Even a child should be able to spot that they were not right. The passenger side still had the correct bolts.
The bolt on the left is incorrect (7/16-20) the two on the right are correct.
The drivers side only had the middle bolt and two of the incorrect bolts. It should have had two of the middle bolts and one of the bolts on the right.
The correct bolts (from my measurements) are M12x1.75. M12 (0.4724") is bigger than 7/16 (0.4375"). A thread pitch of 1.75 is roughly 14TPI.
Hopefully the nuts haven't been too badly damaged by this.
Some vendors say the correct bolts are 1/2-13 but the overall diameter I measured is too low for this, Based on my thread gauges 13TPI was wrong. I can take some photos showing this if people want to see it.
