Bwmurph
How close is the upper Fan Srroud supposed to be to the radiator on a '59 ? Mine seems to be about 1/4" away on the right side and about 7?8" away on the left side. I'm sure this can't be right. Also, is the lip on the shroud supposed to fit into the lip on the radiator ? I don't see how it can with the outlets for the hose and the filler neck in the way, but it would seem to me that this would be an ideal way to seal the shroud to the radiator and reduce air leakage around the shroud (if a dummy like me can see that, why didn't the General's eng's ?)
Also, just where and how does the long rubber seal go on the hood to seal the area at the radiator ?
I'm getting really tired of this car overheating and then "burping" coolant at the slightest traffic jam or even a long redlight. It's not even that hot here today (upper 70's - low 80's), but cruised down Main St where their holding a bike rally and got caught in traffic and within minutes it's overheating; drives me crazy.
Will a later model C-1 radiator and expansion tank fit in a '59 ?
Any suggestions are appreciated,
Thanks,
Bernie O.
Thanks,
Bernie O.
