V
Vette66AirCoupe
I need some help diagnosing a problem with my parking brake warning light on my '60. The power comes directly from the junction box via a wire with a female connector that plugs right onto a male prong on the left side of the fuses. According to the Assembly Manual this is correct. The powered wire goes into a mechanical switch mounted on top of the emergency brake shaft. It exits that switch and goes to what is called a flasher assembly. It exits that assembly and goes to the bulb. I've established that there is power through the mechanical switch which is operating properly, that is, the power goes on and off on the exit side when I operate the switch. I have power at the entry side of the flasher assembly but nothing coming out. One thing that has me perplexed is that I can't figure out why the flasher assembly is even needed. When I tested the bulb, which is a special bulb just for the emegency brake warning, it started blinking on it's own after a brief warm up.
Two questions.
1. Where can I get this assembly #3737979?
2. If I can't find one, can I just simply bypass this flasher assembly or is there a downside? They must have put it there for something. :confused
Two questions.
