RJS91RGTP
Good morning from Chicago!! I own a 2002 Coupe with about 14K on the clock. My problem is a drivers side window that will not work after shutting the door and the car is started. Other side works OK. I have done some self diagnosis and and have found that if I open the door to the full open position, the window swithch works???? If I close the door it does not. I suspect the problem is in the wiring coming out of the door going into the car in front of the driver seat. There is a rubber sleeve that comes out of the door and goes into the car body and I suspect the wires run thru there. Anyone had this issue and is it possible to get that rubber sleeve off and expose the wires? I suspect a wire is crimped in there and when the door is full open the connection is made but when shut the wire bends and I loose the connection. Any insight or help anyone can provide would be appreciated. Thanks
RJ - Suburban Chicago
:confused
:confused
