C
C1ROD
Help Required......
I own a 1954 corvette and require some measurements as what I have is in the process of being turned into a steet-rod or Retro-rod.
What I need is - from any given noticeable point on the frame. ie centre of the main crossmember, front point of the frame, rear point of each main crossmember. any other point would be a big help too...
To the centre most point of the radiator core support bracket that is located on the front crossmember.
Why I require these the car I purchased had no front or rear suspension mounted to it or supplied when purchased.
I am in the process of mounting C5 front suspension to the frame , while the bracketry is no real problem the position is....
Any other information or help would be very much appreciated. As Corvette's of the early era's are hard to find here in Australia to get this kind of information.
**Number of 1953-55 corvettes in Australia number only 3or4
(mine being one of them).
So If someone has the body off their C1 and they dont mind giving an Aussie a hand with some information it would be a big help "Thanks Mates at CAC"
I have now got it all sorted Thank-you.......by a contact at Corvette Forum.
