Larry,
Man, I get tired just listening to your progress. Amazing!
Thank you for the suggestion.The body shop has all of my new finishing trim except for the bumpers for any test fitment thats needed.Unfortunately they left the upper grill trim in the car when they sprayed the slick sand and its covered with over spray.I hope I can clean it up. They are done with the majority of the body work so when I return the car to him on Monday I will pick up all of the trim parts so nothing else gets damaged .studiog said:Larry,
The car looks great. Your rate of progress is tremendous. I don't know if this will be a consideration for you or not but if they did body work around the front grille area I would test fit the old chrome mouldings holding them in place to be sure you are happy with the fit. Just a thought.
Thank you again for thinking of us (me and my car)studiog said:Hey Larry,
I'm sure your body guys probably have this covered already but just in case... Be sure your body colored headlight trim rings fit good to the body. I've seen some off so far you could almost stick your finger in the gap.![]()
Yea67HEAVEN said:Meeting yourself in corners yet, Larry?
Busy, busy, busy.![]()
You know you are 100% correct,Me personally am not one to not get what I want.But after having some email confersations with some of our forum members there was alot of suggestions to keep it classic looking from the outside.67HEAVEN said:Larry,
I think I'd be having a private conversation with the shop owner. During said conversation, I'd be smiling that thin rat-smile that Philadelphia lawyers use when getting ready to slice-and-dice their next victim.
Following our friendly conversation, he'd be getting ready to paint a bathtub if that's what I wanted for a hood.
Thank You. The pressure is off me for this week because of the holidays,I am dropping off the hood that came with the car (it has a backwards tear drop scoop on it) He said he will use that to double check the corners and If I O.K. it they will paint the car with out the hood and just paint the hood latter. I may just bring the car home for a while untill I can get my hands on a reproduction hood. I can get a hand laid hood no problem but the press molded ones no one has them in stock and it seems the places that makes them are not building any till after the holidaysMrmike said:Larry,
Have you called Vettegal 858-451-1933 Mary Jo Rohners vettegal.com. She might be able to help. She has a unique collection of used parts and has been real helpful in having or finding what I have needed. Also paragon used parts department is pretty good on used fiberglass.
Just a thought. Good Luck.
P.S. I know it is NONE of my business but I would stick with your first instinct and go with your custom hood. Watching your project from a distance I am impressed with your judgement and decisions that brought you this far. Keep up the great work.
