IH2LOSE
- Joined
- May 24, 2001
- Messages
- 3,908
- Location
- We Will All Meet Again
- Corvette
- 1966,and a 1962 thats almost complete
Thanks to Midyear (dennis) I installed a midyear exspantion tank on the 62 so I would have a way to fill the system. I have a radiator in the car with no filler on it. I used a special thermostat housing that had a cap on it and I would fill it thru this cap.But I never liked it and with the tri power set up I am getting (de-layed till December But I am told I should be getting one of the first ones) it uses a special thermostat housing so I had to make provisions to fill the system else where.
I replaced the filler neck with a standard thermo stat housing. I mounted the exspantion tank on the passengerside of the car by the hood latch and I tied it into the suction side of the water pump.between the water pump and the heater core. .Is this the normal location of it on a vette?. I am still having problem filling the car with water/antifreeze.I have a 160 thermo stat in the car and with the car cool I can only fill the system up to the thermostat.The car will idle all day with the fan on and not get above 140 degrees (infered thermometer aimed at the thermostat housing) and not allow the stat to open.If I uplug the fan and let the car run the water level in the exspantion tank never goes down it seems as soon as the stat open the water rushes out of the exspansion tank. I think I have to vent the top of the radiator and run it back to the top side of the exspansion tank to allow the air to get out.(I welded the vent closed on the exspansion tank)
Also dose anybody know if I could just install a restrictor in place of the thermostat this way I dont have to worry about being air bound when refilling the car? I know if I dont run a thermostat I would get too much flow thru the radiator and not be able to remove any heat from the fluid.
I take a phot and post how it looks.
