B
Bad65
OK...I need to stop looking under the hood because I keep finding little things. I have noticed small accumulation of gas under the carburetor. I tried to tighten the bolts on the carb and noticed the front left one was stripped. I removed the stud to discover it was stripped in the manifold. Autozone guy recommended to use some "glue" insta something and fix it that way. I want to fix it the right way. Any recommendation? Tap and Die the hole bigger and use a larger stud? Any ideas... I know someone out there has experienced this before and has the right solution.
Thanks!
Vanessa
Thanks!
Vanessa
