- Thread starter
- #21
brumbach
Brian:
With the advise you've given, I can now make an informed decision. I owe you. Thanks so much. Good luck with the studies.
Bill
Bill
allcoupedup said:Hey Bill,
Thanks for the compliment but I must say everything I know was pulled from kind people on internet forums like this.... and I did my first rebuild last year and didn't do all the HW I needed to do before hand.
This is what I'd do if I was in your situation.
#1 - CC the cylinder heads
#2 - do some research to see what the factory deck clearance should be and then what a typical deck job takes off. You can then get a estimate of what you'll be left to work with. .025 may be a good estimate
#3 - Select your pistons based on #1 and #2. You can play with the calculator using the data from #1 and the assumption from #2. You can then modulate the dome size and and pick a middle of the road head gasket like .029. You should then be able to determine whether you need flat tops or domed pistons. Buy them and send to builder
#4 - When all the stuff arrives at your door, assemble the short block and take piston/deck clearance measurements.
Step #1-#3 above should get you close to your target compression ratio.
#5 - select a head gasket anywhere from .015 (steel shim) to .039 composition to fine tune your compression ratio with your updated piston/deck clearnace. (may even need to use different head gaskets on each side)
IF - the assumptions were bad and you can't get where you need to be with head gasket selection, you can mill the heads or unshroud the intake/exhaust valves to adjust but this is unlikely.
I'm supposed to be studying right now so I'll illustrate in order to extend my procrastination:
Measured: 62 cc combustion chamber
assumption: deck clearance: .025 , bore =.030, head gasket = .029
known: stroke = 3.25
dome = 0 (flat top)
CR from calculator: 10.26
now let's say you assemble it and the deck height is .035 and you've already selected flat top pistons.
bore = .030
stroke = 3.25
dome = 0
head gasket = .015 (you can get away with this because your deck will be true - your heads should be true too - there is little tolerance for warpage with steel shim gaskets)
CR from calculator: 10.37
on the other hand... if your heads were 66cc
deck clearance = .025
bore .030
head gasket = .029
stroke = 3.25
dome = -5.33 (OEM SHP pistons)
CR = 10.44
if you changed to .039 head gasket CR = 10.17
Just play with the calc a little bit and you'll start to see how all these factors change compression ratio.
good luck! A wise man once told me MEASURE TWICE AND CUT ONCE. Some people might think it is overkill to take all these precautions but it will help you understand what's really going on inside that motor and if you ever have to make any changes in the future, you'll know exactly what you're dealing with.
Brian
