6
67ragtop
Does anyone have a good method for installing intake manifold gaskets on a 67 327/350? On my first attempt I installed the gaskets dry. The front rubber gasket popped out after I tightened down the intake. The second try I used some high temp sealer/tack to glue the rubber down to the block. This lasted until the engine got warm and then the front gasket popped out again. My third try I tossed the rubber gaskets in the trash and used black high temp RTV in their place. This lasted for 60 miles then developed a nasty oil lead at the rear by the distributor (I did confirm that it was leaking between the block and manifold). Each time I cleaned the block, heads and manifold and used new gaskets. I’m not sure what to try next.
