Ok, I got my new floor jack and jackstands yesterday.
I purchased the Sears aluminum 4000lbs jack and 2 sets of the 6-ton jackstands. I know the 6-ton stands might be a bit of overkill but they were only $10 a set more than the 3.5-ton stands so I figured it's a lot of extra safety margin for a small amount of money. Also, It looked as though the feet of the larger stands were a little further apart which should make for greater stability.
Now, as I'm aware that if everything goes properly, this should be a safe and uneventful process of getting the car up and down on the stands but i'm also aware that doing things the wrong way could kill either the car or more importantly myself so I'm following Larry's (IH2LOSE) constant advice to me of "THINK IT THROUGH FIRST".
First thing I did was look in my Shop Manual for proper placement points to jack up the car. Fine, easy, no problem there, it's easily shown. I made sure the car was in gear & emergency brake on.
the drivers side is fairly close to the garage wall so figuring that was the more difficult side I better start there first. Not having much room to work I have no choice but to have the jack as an angle to the car, approx 45* or so but I got the jack saddle carefully under the frame rail in front of the crossmember at the front point on the rail that the manual shows, got the saddle of the jack snug up against the frame and double checked it was centered on the frame, etc and started to slowly jack up the one side and STOPPED. The car was shifting all over the place - a little front to back movement but a bunch of side-to-side movement and the jack kept following where the car was going. WTF!!
Why is the car moving all over the place rather than just lifting up on that side as it should be doing? I'm guessing the jack moved a good 3-5" from where it originally started on the garage floor?
I was not comfortable proceeding any further after that so I carefully lowered the car back down on it's tires and decided to ask a few questions first.
1. is the jack moving like that somewhat normal because as the car is raised on it's side the jack is just following it as the weight of the car on the jack is keeping the jacked centered under the frame rail as the angle of the car being raised changes it's position?
2. the shop manual specifies front jack placement at the very front of the car at the front edges of the frame rails in front of the crossmember ahead of the front suspension but it doesn't say or illustrate where the rear jackstands should be placed.
sorry if these are really stupid questions but i've never put a car up on stands before and I just want to be able to work on my car - not kill myself or cause major damage to the car in the process.
