- Thread starter
- #21
Heaven
thank you!
the pics are VERY handy and help a lot, especially on stand placement
thank you!
BarryK said:Mark didn't give me a real answer........... it's because this is the only thing he worries about jack up
allcoupedup said:I jack mine up on the side rail - just forward of the transmision x-member - both wheels on one side come off the ground. I raise it just enough to slide in the jacks on the lowest setting. Then I do the other side + 2 notches, then back to the original side + 4 notches, then back to the other side + 2 notches. At no point is it close to tipping. I use 3 ton jack stands. Brian
BarryK said:Chuck
do you place the stands at about the same points as 67Heaven?
