Hi Tigernut,tigernut said:Anyone know what the rubber cone shaped firewall/engine compartment plugs are called and where you can get them new?
Thank you,
Doug
Yes, yes and yes again. I learned the hard way.JohnZ said:Tip - Order more than you need, as you'll probably damage some while installing them. Dip them in a 50-50 water/soap solution first (Joy, etc.), use a round-shank Phillips screwdriver as a tool to start them through the dash mat and firewall, and have a helper on the engine side pull on them with duckbill pliers while you push from the inside until they're seated.
