I've got a question on the seat cover installation. I've only found pictures online for this procedure from the Rowley Corvette website and it didn't include pictures of the seat back install.
I currently have the seat cover installed to the foam and frame via the inside seat cover rod and small "s" clips.
I then installed the outer diameter rod and small rod across the bottom of the seat cover.
When I stretch these over the seat back frame, where do I attach the clips to on the frame and which clips do I use (small "s" clip, large "s" clip or hog ring)?
Thank you.
Doug
Thank you.
Doug
