ok, ok, I know this issue has been beaten to death on all the various Corvette forums but as I searched I never saw a direct answer for this particular tire size question.
I need to replace my tires on my '65 coupe this winter and I'm currently running 205/75/15 Goodyear Invecta's which were on the car when I bought it. I'm noticing some waviness along the sidewalls and I'm just not at all happy with the performance of the tire. I also get just the slightest amount of rubbing at full turn lock against the frame rail. Just enough rubbing to put a mark on the frame but that's it. I'm assuming the rubbing is because the 75 aspect tire is a bit taller than the standard 70 aspect.
I'd like to run Goodyear Radial GT's in 235/60-15 which my neighbor had on his '67 with no problems.
I currently have the stock steel wheels but also plan on upgrading eventually to the repro bolt-on KO's.
My desire is to have a wider tire for a nicer and "tougher" look to the car and also try to improve the handling a bit but obviously don't want any rubbing issues.
I did a search comparing the standard 205/70-15 against the wider 235/60-15 and came up with these numbers:
205/70-15:
Sidewall: 5.6"
Radius: 13.1"
Diameter: 26.3"
Circumf.: 82.6"
235/60-15:
Sidewall: 5.6"
Radius: 13.1"
Diameter: 26.1"
Circumf.: 82.0"
Between the two sizes, the sidewall and radius compare as the same, and the 235 tire has just slighter smaller diameter and circumferance. Based on that, I'm figuring it should fill up the wheelwell almost as much and should also eliminate the slight rubbing I'm getting on the front frame rails but not create rubbing elsewhere and will give me the wider look i'm trying to obtain.
Any comments?
Anyone else running 235/60-15's that can comment or say if my calulations are off?
if I really need to I could drop down to a 225/60-15 but a lot of this choice was based on the looks and the fact that there were no rubbing issues at all with the 235 tire on my neighbors car.
thanks for your help.
Barry
205/70-15:
Sidewall: 5.6"
Radius: 13.1"
Diameter: 26.3"
Circumf.: 82.6"
235/60-15:
Sidewall: 5.6"
Radius: 13.1"
Diameter: 26.1"
Circumf.: 82.0"
Any comments?
Barry
