C3: 1976 Deluxe Passanger Door Panel
twamd80driver
Cleveland, OH
1976 L-82 4-Speed
I Need to replace my pax side door panel. I have a couple of questions though.
1)Does the woodgrain panel pop out, and how can I do this?
2)What is the best technique to remove the old carpet from the panel, and what is the best way to glue it on the replacement panel?
3)Does anyone have a 1976 Deluxe pax side door panel in white for sale?
I would appreciate any help on the subject!
Chris
The woodgrain panel is removable, and is very easy. Once you remove the door panel, you will see that the woodgrain inserts are just screwed into the door panel. So is the trim that goes around the woodgrain, and the trim at the bottom where your carpet is. All very identifiable once you see the backside of the panel, and all very easy to remove and re-install.
Sorry, but I have no recomendation for your second item.
