L
Lee74C3
I took Friday as a vacation day and made a three day assault on the 1974
Coupe. Insulation, rebuild heater box, heater core, new blower motor with
larger fan and 7/8" spacer, carpeting, and a whole bunch of other interior
trim pieces.
I am happy to announce... my HVAC fan no longer SUCKS (!)... it BLOWS (very
hard). The fan recommended by Ernie at Wilcox (p/n 52466047) does make a
difference. In addition, I sealed and taped all connections for the ducts
and repaired the plastic connector that moved the temperature door. I
still need to get the AC charged. I get significant air flow from all
outlet positions.
I had the entire dash out of this car. Despite taking good notes at
disassembly, I was apprehensive about connecting voltage to it again. I
pushed it out of the garage (my wife would really hate it if I burned the
house down), placed a big fire extinguisher in close proximity and, got out
the BIG bolt cutters in case I had to cut the battery cables fast.
First, I connected the battery cables and was pleased that buzzers buzzed,
dash tell-tale lights came on etc. After letting the car sit for about 10
minutes and not seeing any smoke, I turned the key to start... and it
started right up! Except for two items noted below, everything works.
I do have two small issues yet to sort out and would welcome suggestions.
1) The right side plenum vent door (which I rebuilt with a new seal) opens
when it should be closed. It is closed in all positions except AC MAX. In
AC MAX, it opens. I think I have a vacuum hose(s) connected in the wrong
place. Which one and where?
2) The vacuum switch to override the headlamp doors... I can't figure out
what it was attached to under the steering column area. Maybe something is
missing on my car. The trip odometer reset is in place (it is hard to turn
due to bends in cable). It appears the headlamp switch is mounted inboard
of the odometer reset... where? The AIM is unclear in this area.
FYI - the ACC carpeting I purchased from Wilcox looks great. It required
very minimal trimming. The hardest part of the carpeting job is the
wheelhouse area on each side.
Thanks to everyone who provided guidance in this project.
trim pieces.
outlet positions.
