I need some help concerning the oil pressure control line that sends oil into the oil pressure gauge in the center console. While working on installing a new clock, I broke the oil line right at the fitting. It looks like the line that broke off and is still on the fitting should slide off and then the remaining line simply slip over it the fitting nipple, but it doesnt want to move and I don't want to damage the fitting. Is this fitting an integral part of the line, and I should replace the entire line from the engine to the gauge cluster? Or am I correct and I should somehow remove the broken line off the nipple?
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
