J
jeff72
Hello -looking for some quidance on changing the radiator fluid in my 72 before the WI winter strikes full force.
I read in popular mechanics to drain the old fluid -fill with water -run the engine until the thermostat opens -drain, fill again -run the engine, then drain and fill with radiator fluid -top off with water.
the article indicated that it would be politially incorrect to flush it with a hose and let it run out into the street. :ugh
does this sound like a good method to anyone -the article states that the above procedure would purge 99% of the old fluid.
thanks
thanks
