L
Larry Dana
My '82 was not shifting properly, during normal acceleration, it would cycle through the gears way too quickly, (it would have gone through the gears and be in 4th gear and I would be barely going 25-30mph).
I took it in to my local chevy dealer and they said the transmission needed to be replaced, so, several hundred dollars later I had a new trany.
About three weeks later it started to do the same thing again, took it back and they said the trany they had put in was bad and needed to be replaced (no cost of course), so they did.
It has been almost three months now and guess what? it is starting to do it again! I have a hard time believing three bad transmissions.
Does anyone know if there are any external controls that determine what gear the transmission thinks it should be in? for example a vacuum line, or electrical signal from speed sensors, tach, computer or combination of above? (I would like to understand the workings a little more before I take it back in)
