AV8R
Problem description:
LHS headlamp/headlight assembly won't fully open or close after turning on the headlight switch.
Year/Make/Model/BodyType:
1990 Chev Corvette C4 (white coupe, Southern California its whole life)
84K miles, mostly round town and some freeway trips.
Details:
Ive tried numerous times to turn on and off the headlights where every time the right works perfect and just recently the left side partially opens and doesnt respond there after. I can however open and close the left side manually by turning the headlamp motor knob until it gets to either end of the thread where it stops and the assembly will be either fully up or down. This leads me to think that the gears and bushings are fine, rather the problem must be electrical in nature. Also, with the hood up, I can watch the right side motor's knob spin but not the left side.
What I want to try next:
Later ill get my kid to turn the switch so I can examine the left side closer to see and hear if its making any noises in trying to respond.
Also, I may try switching the left and right side electronic headlamp module (assuming L and RHS are the same, and use separate modules). If this is a good test, then I should be able to see if the problem is with the electronic module or not. If its one module for both, it will require cross wiring jerry-rigging.
I will also see if there is power going to the cable that drives the motor (grey and green I think). I may also try apply power directly to the motor to see if it responds. Will use my battery charger rather than directly to it via battery cables so that the power is limited.
If the problem isnt the electronic module, the motor seems fine, then it will likely be somewhere in the wiring or some thing else upstream from the module. Here Id need more help from others.
Homework and references:
In researching this problem, Ive found some very good links that are helpful, I will list them here for others to follow the breadcrumbs:
Link to C4 electronic module functional schematic:
Headlight clicking and half-turns - repair with pics... - Corvette Forum : DigitalCorvettes.com Corvette Forums
Note: this diagram implies theres one module for both headlamp motors.
If so, it would require a replaced module if either side was faulty.
Id also have to cross wire to test if one side could drive the other.
Headlamp bushing and gear replacement, steps and pictures:
C4 Corvette Headlight Bushing Replacement 1988-1996 | CorvetteMagazine.com
Another step by step with pictures:
Make Your C4 See Well
Where to find the bushings, gears, new or rebuilt headlamp motors:
Corvette Parts and Accessories, Ecklers 1-800-327-4868 - Corvette Parts and Accessories
More resources would be appreciated:
Wiriing Schematics
Pictures of where the module is
Step by step procedures for debug and fixing
other insights in fixing the headlamp problems like mine
Bst Rgds,
Thomas
Details:
Wiriing Schematics
Bst Rgds,
Thomas
