mjlisz
Hi Folks,
I have a 1990 C4 with a standard L98 engine and 6 speed transmission. I discovered coolent in the oil pan awhile back and concluded that i must have blown a head gasket or similar. Not sure what happened there. I don't drive it hard at all and it only has 100,000 miles on it. Also,it looked like there was an oil leak somewhere on the upper part of the engine near the rear because there was always some oil dripping down the transmission bell housing. Not really dripping but you could tell that it was there. Anyway, I decided to tear down the engine and inspect/rebuild as needed. I have removed engines from 300Zx's quite a few times, but never a vette. I did a search on the forum and got a lot of usefull information. But I stil have a few questions I was hoping that someone who has done this before could assist with:
1) What to do with the A/C compressor/dryer canister. Can these just be moved out of the way or does it have to be removed?
2) How high does the car need to be off the ground in order to romove the engine with transmission? Removing them together seemed to be the preferred way. I have already removed the hood.
3) Does the radiator shroud need to come out? I have seen both ways mentioned. But I may be getting C3's and C4's mixed up. The A/C condensor looks like it has to stay in - unless I dissasembe the A/C lines. I really do not want to break the A/C lines.
4) I am also going to replace the clutch while everything is out. Several people mentioned to be sure to use a dual mass flywheel. Does the flywheel have to be replaced if I replace the clutch? Can it be resurfaced? These are expensive!
I was surprised that there were no engine removal procedure in the Chevy service manual which I bought for this purpose. Am I missing something?
Anything else that comes to mind will surely be appreciated.
Thanks in advance for all your help.
Mike
Mike
