C4 Side exhaust
BSH
New member
Victoria, BC, Canada
Does anyone know of a source for an exposed functional side exhaust for C4? Not the rocker cover style that you see in some catalogs. Thanks
it is tough to make an exposed side exhaust for the C4 because there isn't much room to get the pipes directly over from the engine to the side of the car... if you look at the way the Side effects exhaust works, it is bolted on after the cats, then comes over from there... I am not sure if you could do a true side exhaust without a lot of modification to your car
