D
DJS
Is it typical to require the 3 metal trim pieces across the top and sides of the windshield to be replaced when the windshield is replaced? My Corvette Parts strore told me they usually need replacing as they typically get damaged being removed as they are stuck to the adhesive/sealant. When I dropped my 87 Convertible off at the Auto Glass shop today they had preordered the weather strip but that the Chevrolet dealer also sent the 3 trim pieces. But the Auto glass shop returned the trim to the dealer because they said they were not needed. Then later in the day the auto glass shop calls and said the trim was stuck and could not be removed without damage to them. I understand these 3 trim pieces total about $500. For those of you that have had your C4 windshields replaced, did it also require replacing the metal trim? I am a bit confused as to who was originally correct.
