fatbloke-dim
I need the windshield rweplacing in my '06 . I'm in the U.K. , so , as you may imagine, these things are 'unicorn droppings' !! However, out of the blue , I got a call to say the windshield was in stock ,and was the correct version , 'GPS,HUD, top tint' . gps referring to the OnStar mounting area blackout strip extension. Needless to say , when presenting the car , and checking the windshield, the OnStar area was absent. All other details were correct, however . What I need to know, seeing as this looks to be the only C6 windshield in the country , is , can that OnStar box be removed , so I can go ahead and have that windshield fitted ? I realise there will be other things associated with this , such as the main module in the 'trunk' area, but any info on how this may be accomplished would be most welcome. Especially how to actually remove said box/antenna from it's perch on the glass. I don't need any bluetooth, 'phone or any other unnecessary rubbish , the only thing I occasionally use is the nav , which uses a seperate antenna in the dash , so the OnStar will be no loss. Never worked here, anyhoo.....
Thanx y'all
Thanx y'all
