L
lrrp 51
The oil pressure on my 98 takes a LONG time to come up after an overnight soak. After the initial lag it runs OK.
The two things that I can think of that may cause the problem are:
1. The anti drainback feature in the oil filter isn't working well.
2. The oil filter bypass valve in the pan is stuck open.
Either one would permit the oil to siphon out of the main gallery back into the pan.
The service manual isn't very clear on the configuration of the bypass valve (no pictures).
The question is - can the bypass valve be checked out and serviced without yanking the pan?
