C5 horn problem
  • Thread starter Thread starter MARK IT SOLD
M
MARK IT SOLD
Hello to all,
First time here. Hopefully someone can help, on my 00 coupe
the horn will not work from the steering wheel, it works with the alarm and panic button , so I dont think it's the actaull horn or a fuse. I beleive the problem to be in the steering wheel. Before I take it in for service I'd like to try and repair it myself. Any sugestions anyone?
Thanx for any help!
Mark
HI there,
I have had a few where the wiring in the steering column has become worn, due to a number of reasons.
You will have to check out for 12 volts at the actual terminal at the steering wheel.
Two T30 bolts are used to retain the air bag to the steering wheel.
JUST MAKE SURE YOU DISCONNECT THE NEGATIVE TERMINAL, BEFORE REMOVING THE AIR BAG.
Allthebest, c4c5:hb
Thanx for the response! will I need to reset the radio after re-
hooking up the battery? If so, I dont believe iI have the code for
my car, can you recomend how I can get this security code?
Thanx Again for the info.
I have had an intermittent problem like that, but they have started working again. When they do work first one will sound and then the other one will chime in as the first is working. Right now I've got it on the lift checking connections and grounds. Nothing looks out of the ordinary so far.
Thanx dad. I believe the problem to be at the steering wheel, since the horn itself works fine with the alarm or panic buton. I'll have to dig into the steering wheel to see what's up. How about the code for the radio? I know on my 96 impala SS the car came with a sticker on the radio with the #. but I dont recall getting this
with the vette when I bought it new.
Thanx
I'm not sure whay security you are talking about, but I have a 97. I've disconnected the battery servral times with no problrms after re connecting it.
Are the later years different?t
John,
not sure myself about the security code on the radio. it says theft
lock or something like that on the radio. does yours say anything
like that on it? just trying to find out before I disconect the battery
Thanx
Nope does not sound familiar to me. I guess we better wait for the certified GM guys and or gals to chime in.
HI there,
Your Theftlock feature on the radio is only active if the LED, located next to your volume button, is flashing with the car off.
If this is NOT flashing, you do not have to worry about disconnecting the battery.
Allthebest, c4c5:hb
C4C5,
THANX for the info. you seem like you really know your stuff.I appreciate your help!
YA HOOO!!!!! Ifixed it, not sure how. took the steering wheel
apart and cleaned the contacts. when I put it back together
"abra cadabra" it worked. There's nothing worse than not having
a horn. It just leaves you fealing helpless when someone starts
coming over on you or starts backing up to you too close in a parking lot. THANX for everyones input.
