C5 oil change for the do it yourselfer
69MyWay
Auburndale, Florida
1969 Killer Shark
1. Get one C5 in need of an oil change
2. Buy good quality oil and filter (I use Delco filters and Mobil One oil)
3. Get a pair of good quality drive up ramps
4. Position ramps behind rear tires.
5. Depending on how wide you are at the chest, consider putting a pair of 2x6" cut off boards behind the front tires so that it will lift another 1.5 inches
6. Back the C5 up the ramps. Leave it in gear (if a standard shift), set the e-brake, raise the hood, and open the filler cap.
**The drain plug is in the front of the C5 oil pan. This causes the rear of the car to be higher than the front.
7. Squeeze under, with a 15mm box end wrench, remove the drain plug and drain into pan.
8. Remove oil filter
9. pre-fill new oil filter and lubricate upper ring.
10. Make sure old ring came off with filter and screw on new filter.
11. install the drain plug and give it a good snug pull.
12. wipe off all excess drips, etc.
13. Start engine, look for leaks
14. drive off ramps and have a cool drink.
This is what it looks like.
