jrose7004 said:Vettes aren't fiberglass anymore.
Hi, Craig. I see this is your first post. Welcome to the![]()
Regarding your question, I did a quick look through the CAC's Care and Detailing Forum, but I didn't specifically find anything related to scratch removal. There are some threads about the proper use of a clay bar, and even if applying a clay bar doesn't cure your scratch, there are still lots of good reasons for a clay bar treatment anyway.
How deep is the scratch? If it's penetrated through the clear coat, all the way down to the paint itself, it's likely no scratch removal technique will work. Let us know if what you decide to do about this Corvette you're looking at.
-Patrick
Well it depends on money. First I would try the cheap solution and see if you can live with it provided the scratch does not make it all the way to the fiberglass or the primer. Here it is:
- Wash the car and dry off. Use liquid Dawn to get rid of the old wax.
- After drying it use claybar on the whole car with special attention to the area with the scratch.
- If the car paint is in great shape then use some rubbing compound (by hand) on the scratch area only (go about 2 inches all around), follow it with polishing compound on the scratch area only (also go about 2 inches all around and by hand). If you are anal like me wash the area again and use the clay bar as well.
- Get one of the color waxes that closest match your car and use it on the scratch area.
- Wax the hole car with regular wax.
Stand back and see if you can live with the results. Total cost less than $20. Of course you will have to repeat every 3 to 4 months but it is cheap.
Patrick,
Thanks for the info. The scratch has penetrated the clear coat. It is a small scratch as stated. It is in the lower middle part of passenger door. The car is in great overall condition with about 13K miles on it (2003) and the price was very fair. I have called my local Chevy dealer and they say a guy comes in every Wednesday to take care of scatches and blemishes on their used and new cars. They say he's good. I thought I might have him look at it.
The previous owner also gave me factory matching touch up paint. For this I would let a professional do it. What do you think about these options?
