C5
  • Thread starter Thread starter doc6996
D
doc6996
I have a 2001, and the active handling light is on all the time , it come's up that service active handling SOON . if i order the service manual will it show me how to fix this?? the handling is not working at this time. thank's
Sorry, I don't know the answer to your question, but someone will be along soon...
Glad ya made it - Welcome to the :CAC
Later . . . . . .
6 Shooter
Welcome to the CAC! I think that you need to get that to a qualified mechanic ASAP. That light is telling you that a safety system in your car is not working as designed. Have you pulled the codes? The directions can be found in this link:
http://www.corvetteactioncenter.com/forums/showthread.php?t=72535
Pull the codes and post them here. c4c5 specialist will see them and point you in the right direction.
My C5 was showing the "service traction control system" quite a bit (its a 97) until I cleaned the connections to the wheel sensors with electrical contact cleaner.
Cheaper then a service call and worth a try.
Welcome to CAC I get to the Hilsdale auction from time to time usally after some critter gets in the chicken coop ;)
Craig sr.
