Bwmurph
I had my '12 GS out at a car show today and a woman who also owned a '12 GS (same color!) came up to me and said "Do you know you have a screw sticking out of your right side front tire ?" Uuhh, NO I did not !! Tire monitor tells me it's not losing any pressure, but I took it home anyway Get home, pull the screw out and nothing happens, so I'm relieved - for now (it was a small screw)
These tires are Goodyear Eagle F! P27535ZR18, which I believe are run flats. IF I have to replace this tire I would probably change both front tires and would like to go with Michelin Pilot Sport A/S 3+ ZP tires which, I believe are NOT run flats. My question is can I run non-run flats on the front and retain the Goodyear run flats on the back ?
Thanks, any help would be appreciated,
Bernie O
Bernie O
