c68 climate control outside air temp
greenstingray
N.J
1985 z51 coupe, 1969 green convertible
Looks like I found a bad code for my 87 with climate control. The light was blinking I found the procedure on this site. The out side air temp sensor was bad. I replaced the unit, disconnected the battery to reset the codes. Its know showing 00 no codes but outside temp shows any were from 129f to 118f. Its not that hot here in NJ, so my question is does anybody have a clue? Do you have calibrate the air temp once you replace it? Thanks
