- First use of JDSU’s proprietary SpectraFlair® pigment in North America
- Satin Graphite wheels, yellow Brembo brake calipers add style, performance
- Recaro seating, Midnight Sapele wood complete interior
The Black Diamond Edition, available in the CTS-V Sedan, Coupe and Wagon models, will be the first use by an automaker of JDSU’s proprietary SpectraFlair pigment in North America. JDSU, a Milipitas, Calif.,-based optical technology firm, specializes in cutting-edge color solutions for a wide range of markets. Its pigments are used in certain DuPont paints supplied to Cadillac.
In the CTS-V Black Diamond, a dark tri-coat paint is embedded with SpectraFlair Bright Silver pigment. While other luxury makers offer metallic paints, Black Diamond is created through a meticulous process that gives the paint added dimension.
Instead of simply containing small bits of metal, the SpectraFlair pigment in Black Diamond uses aluminum flakes encapsulated in a glass-like substance called magnesium fluoride. The result is a paint that has a diamond-like sparkle as light hits the surface from different angles.
“The CTS-V Black Diamond Edition is like a finely crafted, tailored tuxedo,” said Michelle Killen, Cadillac exterior paint designer. “The base color may be a simple black, but the details and richness of the material set it apart.”
GM Media
