U
UKVette
I have a '91 last of the L98 engine vette with a 6 speed manual box. Yes it's got the CAGS system on it and it's a pain in the a**e. I know where the sensor is on the box, but will this set a check engine light if disconnected? I've seen for sale both a plug in unit to bypass the sysem and just the covers to blank it off. I would like to know before I spend money on the bypass wether I need it (imporing good to the UK is a real nightmare, the muppets over here open your stuff up and if they think its worth more than declared they sieze it, no arguments)
Also the clutch has a switch on it (that I disconnected and bypassed) that meant you had to have the pedal fully depressed before the starter would engage, did the designers not know this would cause premature failure in the thrust bearing in the clutch? I know most cars in the US are auto, but surely you boys wern't starting them in gear and running over granny were you?:L
Rob H, UK
Rob H, UK
