A
allblue
Where is the CAGS and how do I disconnect it?
First, I'd get one of the CAGS bypass kits from MidAmerica, etc., and install it. If you simply disconnect the CAGS wiring on a 96 (your car right?), you will get service codes set (the system looks for correct resistance in the circuit, so something must be plugged into it).allblue said:Where is the CAGS and how do I disconnect it?
Left side. I just did mine two days ago.Tuna said:The wiring is on the right side of the trans.
