W
Wisdom
Is there any way to calibrate the tire pressure sensors on a 2004 C5? Last Sunday I topped off the air pressure on each tire to 32 lbs using an inexpensive mechanical pencil-type tire guage. I was surprised to see that the tire sensors show variances of up to 3 lbs between the tires, even though the mechanical guage was measuring 32 lbs when the air was put in. Is there a built-in calibration routine that I need to run, or are the sensors simply not that accurate?
- Wisdom
- Wisdom
