Caliper lube
pasvorto
SE Minnesota
Do you think I can get away with using di-lithium grease (that I use for the slide on my garage door) on the pins that the disk pads slide on? I am going to have the wheels off to flush and refill the diff so I thought I could lube those at the same time.
I guess it'd be better than none ... but it's wrong. The correct stuff is high-temp & made for brakes ... most any car parts store has it.
JACK:gap
Doesn't really matter much, as nothing is really moving relative to anything else in a fixed Corvette caliper; the caliper is solid-mounted and the pads are in constant contact with the rotor surface and only move a few thousandths when you step on the brakes. It IS important on all other cars with single-piston calipers, as their calipers must slide laterally on the pins in order to press the pads against the rotors, especially if the pads are worn.
Having the grease melt and contaminate your pads will junk them immediately. No grease is required or is of any benefit.
Use it to grease the trunk hinges instead.:beer
