Nut
Ok folks here's my problem. As you may seen posted my brakes crapped out on me on the way to Bowling Grren this week. Sucking air. Where? Up on jack stands, bled them all. Air left front only. Hmmm. But....... I notice something I've never seen before. A wet area on the left side (facing the rotor) of the caliper where the seam is between the two caliper halves. Hmmm...... did I accidentally drip some fluid down the bleeder hose while I was pulling the tube off the bleeder nipple? Don't think so? So I cleaned if off real good and had junior repump the brakes again with everything all sealed up.
Well I'll be........ darned if I don't see fluid ever-so-slightly oozing out between the seam. Remember, left side seam only. Now here's my question:
Can you buy a replacement seal (I assume there is one) between the two caliper halves? I can't find my VB catalog at the moment and none of the other usually parts catalogs show any kind of seal for the two halves. Can this seal be bought or am I looking at a new caliper (and probably both front)?
Any suggestions before I bite the bullet for new calipers. I'd rather fix these as they have been milled slightly to fit my aftermarket mag wheels and I'd really like to avoid the nerve racking fun on the bench grinder like I did the first time I did this.
Thanks all............... Nut
