eoseitz01
I'm doing my first engine build and managed to break a bolt off in my cam while installing the timing gear. My torque wrench obviously didn't click. I know rookie mistake.
I have a spare cam and decided to swap it. I tore off the intake, rockers, push rods and lifters. I'm trying to pull the cam and it hangs up after a couple inches. Did I miss something. I double checked and all 16 lifters are out. Do I have to remove the mechanical fuel pump? Do the lifters run the fuel pump or the camshaft?
Thanks as always.
Sent from my iPhone using Tapatalk
Thanks as always.
