Peer81
Hello,
After several times and houres spent to get the windows right I just about had it right. But!
To begin from the beginning. Doors repainted put back in the car fit perfectly and also align perfectly with the surrounding body!
For the windows. With the doors closet I can get the window up till 1/2" from the top, there it's so deep into the rubber that is stops (passengers window I can get fully up). So I need to change the window setting and get them a little outboard.
Now with the door open, windows fully up I close the door and the window is getting in front of the blow out clip and not behind it. So in this situating I need to change the window and get it a little more inboard. Really this is not a 5 minute job but this is the best I have right now.
As far as I see it the blow out clip is the only problem, without it the window will slide in the rubber perfectly. So the question is, what will happen if I remove the blow out clip and not return it.
As the highways around here are 80mph and in Germany without a limit I don't want my windows to be sucked outboard or is that not possible?
I need to change them anyway as the rubber is from the blow out clips, I already have new ones and I also no in this way I need to change them again next year.
Greetings Peter
Greetings Peter
