corvette66
I want to clean up the junk around my motor. So i am going to replace the smog pump with one of those pulley replacements. Along with doing that I know that i can also remove all the air injection junk on the pasenger side of the motor that hooks up to the smog pump. This will really clean up the motor, and give it a beter look.
How about those tubes that are welded on the top of both exhaust manifolds that run into the air injection valve. Can I remove these tubes and weld the 7 holes shut? (I say 7 holes because one is for the EGR)
There is just one more things that would really make my motor look good. If i could get rid of that AC pump. Is there a replacement pully for that, or could i get a smaller belt and just eliminate the AC pump and tensioner. By running the belt around the crank pulley, right under the water pump, up over my smog pulley to the alternator then to the power steering back to crank.
http://corvetteactioncenter.com/forums/misc.php?do=getsmilies&wysiwyg=0#
