O
omega1940
I had an earlier post on some new gear I purchased that has not been installed on my 88 L-98.
Right now I have a 52 mm. Throttle Body, "Vortex" behind the throttle body, K&N, Open Filter Housing, adj. fuel pressure, Y-Pipe (no precats) free flow cat and Flomasters. (I didn't know there were different types, but these are great.
Anyway, I bought a an Accell Super Ram, Crane Gold Roller Rockers (1.6) Accell Plenum and long tube runners plus 24lb. injectors.
My 88 blew a head gasket so I decided to take care of the upper engine while it was broken down. I now find that I need to modify the heads and valves and add a new cam.
Can some of you experts give me the best advice on Brand name cams? I've seen "Crane Flat Tappet cam w/.470 lift, 226 duration" but have no idea what that means, other than it holds the valves open longer I assume. Since my heads are out, can I have them ported. I saw someone mention AFR 190's and ported 113 heads?
I need some help right away. My mechanic says he needs to get the car back together by Wednesday of next week. (4/23)
Will this give me the "balance" between intake and proper compression ratios, etc.
Thanks very much.
Mike
Thanks very much.
Mike
