firstgear
- Joined
- Oct 11, 2003
- Messages
- 1,895
- Location
- Norwalk, Ohio
- Corvette
- 15 Z06, 01 Vert, 63 SWC & 60 ALL RED
Got my motor mounts from Myers Racing to weld on the 60 frame...also bought from Summit a set of polyurethane small block chevy motor mounts as well as the bolt that Summit lists as the bolt to attach the motor mount to the frame mount....
Here is my question....just looking at how it goes together it appears to me that the amount of clearance between the bolt and the frame mount is too much
and that the clearance between the motor mount and the bolt is too much...seems to me that the motor could "rock" way too much...
add up all the clearances and it seems way too much.....those of you that have put these things together before....what do you say?
this is the mount I bought
link to mount: http://store.summitracing.com/default.asp?Ntt=motor+mount&searchinresults=false&Ntk=KeywordSearch&DDS=1&N=115&target=egnsearch.asp
these are the bolts I bought
link to bolts: http://store.summitracing.com/default.asp?Ntt=motor+mount&searchinresults=false&Ntk=KeywordSearch&DDS=1&N=115&target=egnsearch.asp
ok......comments??????
