XtremeVette
Can't get my 90 to run...it cranks but won't turn over
ok....heres what happen....car was running then all of a sudden starting missing. I stop the car pulled over checked stuff.....found that the temp gauge was reading really high.....265 temperature.....Shut car off....tried starting after that point....no go....haven't been able to get it running...car cranks...but will not turn over.
I had a custom chip in it.....replaced it back out with the original chip....still same problem
I have spark at the plugs and have voltage at the injectors
I checked the valve on the fuel rail and fuel came through when tried to start the vehicle
I checked for codes on the ECM...none....blinks code 12 3 times and goes away...
BUT!!!...i disconnected both the Thottle Position Sensor and the MAP sensor to attempt to get a code to be thrown.....checked the ECM with my code scanner and again....just code 12......reconnected things back together.....so.....Iam very much lost right now...
I also have already replaced the cap, rotor, upper coil, lower pickup coil, ignition module....still no luck
anybody have a clue what to do? :eyerole
thanks
jeff
thanks
jeff
