Hi,
Last weekend without warning, my 1986 C4 coupe stranded me at a shopping mall and would not start.
Got back into the car to go home, lots of cranking of the motor happening, but not on your life would it start.? .. had to get towed home.
I just want to be sure I am on the right track with identifying the problem.
What I have found out so far...
When I turn the ignition key on,
* The fuel pump is silent,
* there appears to be no spark getting to the plugs.
* The engine will crank over fine,
* there is plenty of power in the battery.
Is this the VATS system immobilizing the car? I have read some conflicting information in forums as to this .
The symptoms I've described above sound similar to a VATS problem I seen described in other posts, but I wanted to be sure.
Some state categorically that if the engine will crank over, then it's not a VATS problem.
Others say ...
If the engine WILL CRANK and a code 53 is displayed, that indicates that the VATS decoder module has detected a correct key resistance, and has grounded the relay coil negative wire for the start enable relay, but that the ECM is not receiving the VATS signal from the module. That can be caused by either a failure of the VATS module output which generates the signal, or Circuit 229 between the VATS module and ECM is open or shorted to ground.
I've tried starting the car again a number of times in the past 24hrs, and there is no change at all.
any similar problems experienced by others?
If it's not the VATS ... then are there any idea as to what else could suddenly knock out both spark and the fuel at the same time?
Others say ...
